Question about coil on 2.8L V5 engine.
Old Oct 30, 2010 | 02:40 AM
yukoncornel's Avatar
Default Question about coil on 2.8L V5 engine.
I have a cylinder 1 misfire. I was planning on swapping that coil out with the cylinder 2 coil to see if the problem followed but when I removed the coil rack and disassembled it I found that the 3 coils are hardwired in and cannot be swapped.
I've already installed new plugs and wires. As far as the coil goes, is there any way to eliminate it as the culprit without buying an entire new $130 coil? I thought the 3 coils were individually removable but that does not seem to be the case.
Also, the misfiring is intermittent so I doubt a secondary coil resistance check will show anything.
Any feedback is much appreciated. Thanks
edit: vehicle is a 1998 A4 2.8L V5 engine.
hockeyace101
Mar 2, 2011 10:55 AM
mugman21
Nov 8, 2009 07:02 PM
paulywalnuts446
Nov 4, 2009 03:27 AM
johnwpavia
B7 Models
Aug 30, 2009 06:42 AM
