Question about Panzer plate install
Old Dec 27, 2009 | 04:45 PM
msemaniuk's Avatar
Default Question about Panzer plate install
Guys,
I'm getting ready to install a Panzer plate on my Avant. I'm thumbing through the instructions and there is mention of greasing two of the 10mm bolts & corresponding washers. What type of grease should I be using for this? The closest thing I have in the garage is white lithium grease, but I don't think that will stand up to the elements well.
-Mike
Old Dec 27, 2009 | 05:35 PM
flynnr's Avatar
vaselene should do the trick
Old Dec 28, 2009 | 09:17 AM
msemaniuk's Avatar
Turns out I had bearing grease & used that. Thanks for the suggestion though!
-Mike
Old Dec 28, 2009 | 10:06 AM
RockyMountainB5's Avatar
Hope you have a better time with the install than i did - the instructions from dieselgeek.com were WAY overdone, and overly complex.
Just put the wings on, put in the rivnuts, and be done with it.
BTW - not knocking the panzer plate, i fu&*in LOVE mine. Its already saved my oilpan.
Old Dec 28, 2009 | 11:48 AM
msemaniuk's Avatar
The install sucked. Took way longer than it should have because things didn't really line up the way they should have. I had a lot of trouble with the passenger side of the front spoiler where the plate didn't want to stay in it when things lined up. This also became a factor when trying to attach the plate to the wheel well. I literally had to use my jack to push the plate up high enough to get things to line up correctly. I also had to eliminate one of the nylon washers on the drivers side of the front of the plate because the screw wouldn't engage with it in place.
Now I'm not looking forward to my next oil change.
-Mikie
Mike1.8t
Jul 27, 2010 09:57 PM
StormUnite
Jul 24, 2010 03:45 AM
zipnsplat
Dec 1, 2009 05:29 PM
csswitzer
Aug 18, 2009 01:02 AM
warranty225cpe
Nov 10, 2008 05:42 PM
