Radiator tube ?
After everything was reconected after changing the breather tube fittings,I started the car and emediatly started leaking radiator fluid out of the back of the radiator tube that connects to the block. Now I dont remember it havig a gasket back there. but I could be wrong. anybody know if it does or not? The bolt are pretty tight, but it leaks really bad.
not sure? I didnt take the sensor off. It didnt leak before I took the tube off. Now the tube I am talking about runs from the back of the block over the intake maifold and connects to a small radiator hose. I dont remember it having a seal on it. but I think it should have.
Yeah there should be an O ring/seal.. If you didnt see one come off with the old tube, then its stuck to the block. From what I know even with the O ring they are prone to leaking on reinstallation. I have not done it, but everyone that I know that has, has ran into a problem wether it was a bad seal/leak, etc.
