Real world results and newb questions...
Old Oct 23, 2009 | 01:26 PM
  #31
AutoUnionFan's Avatar
Here's some good info on Audi/VW approved oils.
http://forums.vwvortex.com/zerothread?id=2237991
I use Mobil 1 0w-40. Some people have had problems with royal purple. You will also want to use the oversized filter, the 1.8t has sludge issues.
Old Oct 23, 2009 | 03:34 PM
  #32
dragonrage's Avatar
Originally Posted by GT03 TJS
i run royal purple 5w20 in the pony car... whats a good weight oil for these cars?
I recommend Castrol Syntec European Formula 0w30 because it's actually thicker than a 30 weight - closer to a 40 weight. It's available mainly at Autozone and is Castrol's best available oil in the US. It has to say European Formula on the front.
Otherwise I'd go with a good brand like Amsoil and run something like 5w40 or perhaps 0w40.
Use a Wix 51333 or equivalent filter. Avoid Fram, though.
Old Oct 23, 2009 | 05:35 PM
  #33
ast03's Avatar
if u want a faster car get a manual.. ur killing urself with an auto
Old Oct 23, 2009 | 07:18 PM
  #34
airguard350's Avatar
Tech Guru
This is why all drag racers use manuals; because the TH350/400 or Powerglide is slow. Also, show me a clutch that can handle 3000 hp. Not trying to start fights, just clearing up misinformation.
Old Oct 23, 2009 | 08:10 PM
  #35
dragonrage's Avatar
sry but TH350/TH400 are definitely showing their age and racers still using them are only doing so because they haven't gotten with the times.
Some automatics are great. Transmissions from the 1960s are not.
Old Oct 23, 2009 | 08:14 PM
  #36
GT03 TJS's Avatar
Theres nothing wrong with an automatic trasmission man... all the 'purists' always try to talk down on them, yeah on a street car they may suck up a bit more power from the drivetrain, but overall, require a 1/4 of the maitenance most sticks do. A simple shift kit and maitenance to the valve body re-gains some of the lost power, firms up the shifts and can be just as mean as any manual...
i'm even considering putting a built 4R70W auto trans with a 3500+ stall in my mustang because when you get to a certain power level it becomes tedious and unenjoyable to drive, especially in traffic. Also, a missed shift while racing can be absolutely disasterous to a car with big power. I saw a Viper break his transmission, driveshaft and bust almost all the valves in the heads at Englishtown in NJ when missing a shift between 3-4. I must say that a Vipers V10 sounded killer at 12000 rpms in 2nd gear.. for about .005 seconds. The following explosion sounded like the end of the world...
aaaanyways, I'm sure a 1.8T with an auto will be just fine once I get it chipped and take care of some minor maitenance issues. All I origional intended to do with this thread was get your reactions to chips, but thankfully I've learned alot more... I'll prob try and pick it up sometime early next week if all goes well. So thanks guys...
Old Oct 24, 2009 | 09:19 AM
  #37
bradtyler02's Avatar
Glad we could help. That's pretty much the reaction I had when I first joined... there is sooo much info to be had here, it's amazing.
As for the TQ specs for the plugs... German car, German specs: gudentite.
Old Oct 24, 2009 | 12:21 PM
  #38
dragonrage's Avatar
For spark plugs, I'd just use the ratchet but hold it at the INSIDE of the ratchet and make it tight. It should be hard (though still possible, so do still exercise caution) to overtighten that way.
Old Oct 24, 2009 | 02:02 PM
  #39
Tech Guru
Just to make a point: http://www.hotrod.com/featuredvehicl...ans/index.html I know a couple of the people that built this car. It has an owner estimated 1,100 hp, runs high 9s, and is using a TH400. I rest my case.
Old Oct 24, 2009 | 02:49 PM
  #40
dragonrage's Avatar
Don't care. Just because it doesn't break doesn't make it good. It's old and inefficient technology. I'd take my 6L80e over a TH400 any day.
