Really Bad! I think
My car sounds like a vacuum! Not a good thing you can hear it inside and outside from 10 feet away easily. I also have gotten a check engine light. I am not sure if the sound is from the engine or the exhaust or what ever else, please help me! What should I do?
Thank you!
Thank you!
put up the codes first. if you heard my car, i don't think you would complain about noise lol. it's probably your secondary air pump no turning off. otherwise the only other noise you should be hearing is the engine. put up a sound clip
Sounds like your SAP line isn't hooked up to your airbox, look at the front of your airbox (towards the radiator) and make sure all the lines are plugged into the box, there is a small line that connects close to the top of the box which is the SAP line. More than likely the fault is a secondary air flow something something rather.
either your pump is bad or it's really dirty because it's not connected to the airbox. the 432 is triggering the other 2 codes. check the hose like auditech said, if that's not your problem, you need a new pump. they're like 20 bux used from a junkyard so get a couple of them. the swap is kind of annoying because you have to take the bumper off and possibly the radiator support, depending on how skilled you are with your hand. (i know some of you smartasses will have a comment for that statement) then undo the harness, hose, 6 little bolts and wiggle the pump out
