Rear end crunch, need help
Old Dec 17, 2012 | 09:32 PM
BradMusser's Avatar
Default Rear end crunch, need help
This is my first time posting on the site, i am a proud of an 2000 Audi A4 2.8. I love my car, but tonight my car had a crunch noise in the rear end while it was in drive it did it for about 10-20 seconds until it stopped. I tried reversing, from a dead stop, but the crunch was more intense and the crunch stopped in drive but when in reverse its very loud and i have no clue what is wrong, one of my bushing on the rear axle is broken, could this be the problem?
Any help would be greatly appreciated. Thanks for reading Brad.
Old Dec 17, 2012 | 09:40 PM
BradMusser's Avatar
It is a quattro also.
Old Dec 17, 2012 | 10:13 PM
redline380's Avatar
Legal Moderator
Welcome to the site. I will ask you to only make one thread at a time about a given issue. Since I am a new moderator my official act of moderating will be deleting your duplicate thread. As for your problem id look at the rear differential. It may be on its way out
Old Dec 17, 2012 | 10:15 PM
BradMusser's Avatar
Thanks a lot, and i thought the one got deleted so i redid it, Sorry. I will check the differential tomorrow. Thanks for your help.
Old Dec 17, 2012 | 10:19 PM
redline380's Avatar
Legal Moderator
No problem. I was kinda itching to use my awesome new powers. but yeah check the rear diff. If it did it once it will eventually chew all the teeth off
Old Dec 17, 2012 | 10:29 PM
BradMusser's Avatar
Thats why i left it sit because i didn't wanna do any more damage, how will i be able to tell if the rear diff. is the problem? Take it to a shop or could i check it myself?
Old Dec 18, 2012 | 03:09 PM
BradMusser's Avatar
The boot on the cv joint is torn, would this create this problem? its been broken for a while and i put it off.
Old Dec 18, 2012 | 03:25 PM
CCA4's Avatar
Definitely possible. Jack up the rear of the car until the rear wheels are clear of the ground. Leave the car in gear and release the parking brake. Grab the axle shaft on the side where the boot is torn and move it around. Wiggle it back and forth, side to side, try to turn it. If you can recreate the noise you're hearing inside, odds are that's the culprit.
Old Dec 18, 2012 | 05:25 PM
BradMusser's Avatar
I found out that the noise is in the middle of the car underneath the drivers seat, so it could be the carrier bearing. Not things i like to hear :/
Old Dec 18, 2012 | 05:26 PM
BradMusser's Avatar
And thanks for your help man
