Rear sway bar?
Old Oct 16, 2013 | 12:19 PM
smittylube's Avatar
Default Rear sway bar?
I have 2001 quattro 1.8 AWM
I hear the rear sway bar S4? helps alot. Is it the RS4 or just S4 I need to look for? I assume only the bushings are needed to change over?
I have not been able to find the info on my searches.
I keep coming up with neuspeed kits and such.
Thanks,
Old Oct 16, 2013 | 01:10 PM
redline380's Avatar
Legal Moderator
I am not positive, but if you have the sport package I believe you would have s4 sway bars already. if you don't have sport package, it may be a worthwhile upgrade. again, not positive though but I am positive that if you have sport package, at least one of the sway bars is s4 spec
bshusted's Avatar
I don't know about the RS4 swap bar, but I'm running the S4 sway bar and it works just fine. You will need the bar and bushings from an S4. At the same time I would recommend adding the all metal end links as the stock plastic links are prone to breaking.
Old Oct 16, 2013 | 02:09 PM
Mad Cow's Avatar
Both sway bars are thicker with sport suspension and are identical to the S4 parts, you won't have to search far to find a set.
Old Oct 16, 2013 | 03:19 PM
smittylube's Avatar
Thanks for that info. is has been identified by original window sticker, dealer and vin it has sport. so I guess I'm good.
Old Oct 17, 2013 | 10:34 PM
smittylube's Avatar
15 mm rear that's all I need I guess
villacorta32
May 13, 2012 06:13 PM
germantech
Dec 24, 2007 02:29 AM
B5luver
Dec 18, 2007 12:42 AM
JettaRedII
Oct 10, 2006 01:57 PM
ronin23
Dec 6, 2005 05:03 PM
