Replace CV boot or Axle?
So i just got an audi a4 2.8 v6 5v (i still dont exactly know what the 5v is) it has a broken cv boot so i will want to replace it since the grease is getting everywhere in the wheel well. I was thinking of just replacing the cv boot itself along with the grease that goes inside which is about 15-20$.
yesterday i was looking at some videos on the Tube to how it comes out and someone mentioned that its around 50$ to replace the axle. which means less grease on me not struggling with the outer axle to come off(i hope). so what do you guys think is the best way to go. i have not heard any noises coming from the axle but it is on the passenger side. i see it as replacing the axle for 50 instead of 20 for the boot now and 50 later for the axle. here is the link Front Right Axle and there is the install guide Audi A4 Front Drive Axle Replacement Thanks |
Sounds like you know the parts price difference between the axle and the boot kit. It comes down to how dirty you want to get. You should search the forum and see how difficult it is to get the cv joint off the shaft too, since you'll have to do that to get the boot on and off. It's faster and cleaner to R and R the shaft assy. 5v is for five valve engine. 3 intakes and 2 exhausts per cylinder. If you don't hear any clicking or other noises your cv joints are probably in good shape.
The stock axles are far superior to aftermarket, just get a boot repair kit. However i've never found a GOOD CV boot repair kit for less than $60. New axles from audi are around $800.
i'd spend the extra bucks, save myself some of the trouble and mess, and go for the axle. i have a cv joint + boot kit just sitting in a box because i don't have a press/reliable way of knocking the two apart and back together.
as for the 5v, your car is a 30v. its a 6 cylinder engine with 5 valves for each cylinder. |
You can replace the joint with hand tools. It's not difficult and allows you to have a new joint on the stock axle, which as stated above is superior to the hit-or-miss aftermarket units.
Originally Posted by Jeff-AudiUSAParts
(Post 1318342)
Originally Posted by auditech79
(Post 1318369)
Originally Posted by Lornnn
(Post 1318370)
as for the 5v, your car is a 30v. its a 6 cylinder engine with 5 valves for each cylinder. thanks for everything guys and for clarifying the 5v edit:
(Post 1318383)
(Post 1318383)
(Post 1318439)
i didn't even bother since i didn't have a press. you're saying removing the old joint and pounding a new one on alone and without the use of a press is advisable?
The stock joint is ALSO superior to aftermarket, i guarantee you the stock joint is fine. Take it off, clean it out with brake cleaner (or put it in a hotsy washer) grease that bitch up, line it back up with the splines and wack it with a hammer until you hear a thud. Slap the new boot on (not a cut or bolt together type) and call it a day. www.ecstuning.com sells a boot repair kit equal to the dealers. |
so you guys are saying to go with the boot and clean the entire joint before adding the new grease right?
Thanks |
I did many cv joints on 5000's, and in looking at the outer front boot kit for your 01 A4 it has the same circlip style parts as the 5000 does. So I'd do this:
remove axle assy put it in a vise, tightly. Take the outer clamps off the boot slide the boot away from the joint towards the vise, or cut it off to get it out of the way grab the splined end with your hand and hit the outer cv with a hammer it will dislodge from the inner circlip without you even knowing it, and slide off the shaft Then you can turn the inner cv bearing wayyy sideways and that lets you remove the balls and the cage. Inspect for pitting or heat marks. Clean, be plentiful with the grease and reassemble. You will find it comes off the shaft pretty easy. There is not much force at all keeping it in place once it's out of the car. So you can get away with hitting it with a hammer without doing damage to the internal parts which are tough. |
| All times are GMT -4. The time now is 06:50 AM. |
