Replaced Alternator-Still not charging
I need some help here...
I'm at the end of my rope with this one.
First I replaced the starter and connected the wiring backwards (oops).
When I started the car after that the battery light on the dash was illuminated.
I replaced the alternator.
I still have the batt light and the battery is not being charged.
So i have to assume that I blew something up but I just don't know where to look at this point or how to figure out whats bad.
This is my only car and I cant really afford to take it to a mechanic and pay $95/hr.
If anyone has an idea I would be eternally greatful.
Aaron
'99 A4Q 1.8t
Aaron
'99 A4Q 1.8t
You could have killed your battery having the wires on the starter backwards. The starter solenoid sort of charges up all the energy it takes to turn the starter hard enough to crank the engine. If that energy got misguided, maybe back into your batter, that would be bad. This is sort of a wild theory, though... Take the battery to autozone or whoever can attempt to charge and load test it.
You could have killed your battery having the wires on the starter backwards. The starter solenoid sort of charges up all the energy it takes to turn the starter hard enough to crank the engine. If that energy got misguided, maybe back into your batter, that would be bad. Take the battery to autozone or whoever can attempt to charge and load test it.
Could this be a problem with the CPU?
If a battery is all it is then I'm on easy street...
They hooked it up to a handheld device and it showed it to be "good"
I may just break down and buy a new battery but would like not to incur the expense unless absolutely necessary.
I have been looking at the wiring schematics of the car and you are right there are no fuses.
Now that I am thinking about wiring it makes me think back to the starter installation. On every other car I have ever owned, there is only a positive connection to the battery and then its grounded directly to the engine block. I have noticed that there is a separate ground wire on this car-or should I say, i have an extra cable down there that looks like it is a ground wire. (I am not talking about the starter interlock relay (50 wire))
I wonder if its possible that this is where the problem lies.
Glad to hear its all figured out. I'm curious as to what autozone did? Was the battery in the car or did you bring it inside? Usually to test a battery they would hook it up to a tester inside the store that lays a charge onto it for awhile and then tests it.
It sounds like they were testing your alt to me.
says the guy whose sn is "Tan Rich Guy" lol.
Anyway, I removed the battery from the car and walked it down the street to an indie parts place. Like I said, they hooked it up to a handheld device and told me the batt was good.
I honestly didnt really believe it so I changed it anyway and voila!
