replacing my clutch/flywheel, any tips?
Old Apr 7, 2008 | 03:11 PM
TeeterTawter's Avatar
Default replacing my clutch/flywheel, any tips?
In a few hours, I'm goin to bereplacing my clutch and flywheel, any tips befor i get started?
Every garage i went to quoted my to bejustunder, or just over 1000 bucks. I don't have money like thatso i am goin to do it myself.
Old Apr 7, 2008 | 05:04 PM
absolute 1.8T's Avatar
Default RE: replacing my clutch/flywheel, any tips?
just get your flywheel resurfaced or w/e, dont buy a new one... it'll save you $800 (should be able to get it done for 60-70 bucks.. cash)
Go stage 2 or higher for your clutch... it allows you to have more fun later, the extra few dollars now is well worth it
oh.. and check for oil leaks while in there.
Old Apr 7, 2008 | 05:07 PM
BzeA4's Avatar
Which write up are you using?
I need to do mine too but its too expensive at the shops.
Old Apr 7, 2008 | 07:47 PM
I already bought a Stage 1 spec with lwfl.
i am using http://www.audiworld.com/tech/eng48.shtml
Old Apr 7, 2008 | 09:35 PM
cbg's Avatar
cbg
Good luck looks um...fun. I know Im gonna have to do it sooner rather than later (106k) not looking forward to paying 1k or doing it myself really either.
Old Apr 7, 2008 | 09:39 PM
auditech79's Avatar
The 1.8T isn't that bad, you just have to take out the back subframe bolts and let the trans hang down (it won't fall) then use a big *** extention to get at the bell housing bolts. The bottom bell housing bolts you have to get from the engine side, if the subframe is in your way loosen the front subframe bolts, but don't remove them.
Try not to crack open the hydraulic slave cylinder line if you don't have to, audi clutches are a bitch to bleed.
Old Apr 7, 2008 | 09:47 PM
tdn's Avatar
tdn
I did a clutch job on my jetta a few weeks ago.. was pretty easy. 5 months ago I paid a shop $500 in labor to replace the clutch on my a4, cheap, but I wish I did it myself though. If it's anything like the jetta, which I'm sure it is, it's not that bad of a job. Having extra sets of hands and a lift will save you a lot of time and trouble.
krimsanavenger
Feb 20, 2011 06:47 PM
teddysart
Dec 22, 2010 12:01 AM
djblack_
Oct 4, 2007 08:17 PM
kraylon
Jun 8, 2007 07:20 AM
