Replacing rear wheel hub and bearings???
I just found out what was causing the chopper sound from the rear when I'm driving. Problem is i need the rear hubs replaced and wheel bearings replaced. Local shop charging me 1100+ for parts + labor. I bought a pair of ruville wheel hubs from aboveallmotorwerks and a kit of wheel bearing from blauparts and all cost me $220+.Question is can i do this myself and leave the pressing to a local machine shop? Is there a DIY link for this job? Thank you.
That's what the tech said when i had my car checked. He demonstrated it by holding the wheel at 12 o clock and 6 o clock and shook it. There was a lot of movement, and said that's what causing the chopper sound and squeeking sound. Could it be just a bearing? He even said he could save me by just replacing one hub cause the other one isn't as bad yet but definitely needed new bearings for both side. Should i just do the bearings first and see how it plays? Or do them all at the same time since im down there? watcha think? And also is there a DIY link? Thanks.
It's usually just the wheel bearing. No sense in replacing the entire hub at this point! If you can manage both rears that would be a good route to take IMO.
Google brought me this:
http://www.audiworld.com/tech/wheel45.shtml
It's for a S4 which I imagine has a very similar procedure. Some of the sizes for tools may be slightly off, I'm not sure.
Also:
http://www.audiforum.ca/a4-b5/21988-...placement.html
Also:
I wish i did buy mine from napa however already ordered from blauparts so i guess ill just go run around town and find someone to press. Okay i'll do the bearings as soon as the parts gets here and post update. Hopefully its just the bearings cuz the damn hubs are a bit expensive. thanks guys.
dont listen to anyone else lol. Ive replaced all four of my wheel bearings by myself (awd) and its cheaper and very easy to do. I paid $30-$70 a bearing and had it pressed eaither for free or $20 PM me and ill tell you the steps thru
Thanks for the links metalman. Just exactly what i needed! Now i got the whole arm out with hub and bearing on it. Is there anyway to tell if its just a bearing or hub thats wrong from here? Cuz if i install a new bearing and eventually the hub was bad already then i might have to get new bearings since pressing out the hub from the assembly could damage the bearings as well. Hope I'm making sense lol. Pretty much i wanna save money and time however also wishing that its just a bad bearing lol. Thanks.
