Rev Limiting at 4500RPM
Old Sep 12, 2013 | 08:37 AM
Pitao's Avatar
Default Rev Limiting at 4500RPM
Hello,
My car is limiting reving at 4500 RPM, that´s too low! What could that be? It cuts injection exactly at 4500RPM.
I´ve noticed, also, my idle is around 500 RPM (too low, I think), and oscillates a lot! ig goes down to 300 and up to 900. When AC is on, it does not oscillates and stays at 600rpm.
What could that be? It´s a A4 95 1.8L 20v ADR (non turbo)
Old Sep 12, 2013 | 08:46 AM
mtroxel's Avatar
You really need a VAG-COM to diagnose this, but right away both ends or your problem make me suspect engine speed sensor. But get some VAG-COM codes before you throw money at this on a guess from some guy on a forum.
Old Sep 12, 2013 | 09:00 AM
Pitao's Avatar
I do need a VAG-COM diagnose asap... I have no VAG COM, I´ll look for one before throwing money on anything.
Old Sep 12, 2013 | 09:02 AM
mtroxel's Avatar
I bought this for $71, then activated VCDS-lite for another $99. Or for just about the price of one trip to the dealer to get some codes read.
http://www.obdtool.com/default1.asp
Old Sep 12, 2013 | 09:14 AM
Pitao's Avatar
The main problem is that I live in Brazil.
I have found this adapter, really cheap:
is this piece ok?
Old Sep 12, 2013 | 09:24 AM
mtroxel's Avatar
I have no way of knowing. It's the right plug, but you need the right circuitry in there. Also don't know the software it runs. You really want Ross-tech's VCDS (VAG-COM)
software. You will save tons of money when you can reset codes, get real time data, etc.
Old Sep 12, 2013 | 12:56 PM
Pbcrazy's Avatar
Just for the record I have no clue why you paid $71 for one, I got mine on eBay for $9 and it works fine
Old Sep 12, 2013 | 07:57 PM
Mad Cow's Avatar
Does it sound like it's at 4500 rpm when it cuts? Does it feel like a 500 rpm idle? I'm asking this because you mentioned 300 rpm and that's so low it would stall within a few seconds of running.
Old Sep 13, 2013 | 09:46 AM
Pitao's Avatar
it sounds and feels like 300 rpm, the car almost stalls then it rev it up to 900, then goes down again.
and it really feels like 4500rpm cut. I´m about to buy a vag com cable, as soon as I have more news I´ll post it here.
is it possible that the car is working in "safe mode"?
Old Oct 8, 2013 | 07:59 AM
Pitao's Avatar
the car got better by itself. no more staling when idle. I think it was old gas in the tank, tha car was not being used for sometime.
but the idle stills around 500-600 rpm, and rev limiting around 4000rpm. is it possible that the RPM counter is counting "half" of real rpm? is the only logic thing.
