rims
Old Jun 14, 2012 | 01:30 PM
20001.8T's Avatar
Default rims
i have a 2000 a4 and i am triyng to put rims from a 2010 they are wider. will i have to use spacers or will they not work at all ?
thanks for the help
Old Jun 14, 2012 | 01:35 PM
CCA4's Avatar
How much wider? Offset? Size? Are you lowered?
Old Jun 14, 2012 | 01:45 PM
20001.8T's Avatar
i did a search after i posted and figured that would be asked. i have the care at the tire place now so i will have to try and figure that out after i get the car back.
he said they didnt fit because they were hitting the control arms. i got them off criagslist, they are audi rims and he told me they came off a 2010. they are wider they what i have now witch are not the factory rims. i bought the car with those on it. i will try to get more info and report back.
Old Jun 14, 2012 | 02:13 PM
bshusted's Avatar
The wheel specs should be cast/stamped into the inside of the wheel. If you have the wheels with you, just look on the back side of the spokes.
Tire size could also be a problem...
Old Jun 14, 2012 | 02:25 PM
CCA4's Avatar
I know that for newer cars, Audi has moved to more aggressive offsets. That right there is prolly gonna give you problems. They're also designed to have wheels with a larger final diameter, so you might need to run tires with less sidewall to make them fit.
Like bshusted said, see if you can get some more specs on the wheels and then we'll be able to help you out with tire width and aspect ratio, spacers, and whatever else you might need to get them to fit.
Old Jun 14, 2012 | 03:20 PM
20001.8T's Avatar
i looked on the back of the wheel and its has a bunch of # so i will give you what i see.
4F0 601 025 cc
8.0J x 17 H2
ET 48
Ronal 1771 i think that is who makes them maybe
80
does this help ?
Old Jun 14, 2012 | 03:33 PM
brrman's Avatar
looks like a 17" x 8" ET48 wheel.
ET48 might be the issue, i believe that puts the rim of the wheel pretty far in to the wheelwell from the hub. You are rubbing the arms on the rear end most likely. You'll need spacers to push the wheels out.
Old Jun 14, 2012 | 03:37 PM
bshusted's Avatar
So the wheels are 17x8 with an offset of +48.
With this high of an offset, you loose 16mm of clearance on the inside when compared to the stock 16s.
Old Jun 14, 2012 | 04:44 PM
20001.8T's Avatar
ya that sounds like the rims, will the spacers work or no ?
Old Jun 14, 2012 | 06:46 PM
bshusted's Avatar
You can use spacers to correct the offset of the wheels. At a minimum I would use 20mm just to get them away from the control arms.
Of course using spacers presents an added cost for the spacers and then longer lug bolts to accommodate. You may want to evaluate if these are really the wheels for you or if they were just convenient.
