RWD B5 Audi?
Old Aug 8, 2009 | 06:53 PM
rcheing's Avatar
Lightbulb RWD B5 Audi?
OK guys, how is this is possible? I was looking up youtube videos of B5's with aftermarket mufflers and came across this burn out video.
Old Aug 8, 2009 | 07:51 PM
hiwords's Avatar
cuz it's quattro baby
Old Aug 8, 2009 | 07:59 PM
yuriy's Avatar
Take off the front drive shafts off a quattro?
Old Aug 8, 2009 | 10:58 PM
Mike-2ptzero's Avatar
You have to weld the center diff(torsen) and then remove the axles, you also have to unplug the ABS. When you do this the whp at the rear wheels still stay the same since power is still being sent to the front diff.
Old Aug 9, 2009 | 02:39 AM
DÌEGØs AÜD!CTIØN's Avatar
wait!!!
...I was wondering about that! Is there a way to temporarily take off ABS/traction control?
Old Aug 9, 2009 | 11:25 AM
ghost6303's Avatar
unplug your ABS module. youl get a CEL but no ABS.
Old Aug 9, 2009 | 11:46 AM
hiwords's Avatar
or you can just pull the fuse. cool thing is my 01.5 has a traction control button that i can turn on and off. ESP FTW!!!!!
Old Aug 9, 2009 | 01:13 PM
2 different things.
ESP button keeps the ECU from closing the throttle to decrease power. The ABS will still engage to control a wheel from spinning faster then the others which happens to be part of the EDL system.
Also to add to what Ghost said, you will also get a blinking brake light on the cluster and a beeping sound when you start up the car when the ABS is unplugged. The blinking brake light on the cluster can be seen in my vids, but because the host sites degrade the video so much it becomes hard to see.
Old Aug 9, 2009 | 03:07 PM
ESP= Electronic Stability Control, not Traction Control
which/where is this fuse?
2 different things.
so this would be reversible right? meaning it will go back to normal as soon as I plugg it back in....
Old Aug 9, 2009 | 03:39 PM
ghost6303's Avatar
just plug it in and clear the codes
