Seafoam for low oil pressure light...
Old May 30, 2010 | 05:53 PM
jhanson25's Avatar
Default Seafoam for low oil pressure light...
Has anyone cured their low oil pressure light with seafoam in the crankcase? I seafoamed my 97 with 0w-40 in it after dealing with the light for a few days and it seems to be coming on less. I don't have the setup to pull the pan and fix it and funds as of now don't allow me to take it into the shop. I do not have any odd engine noise (yet) out of it either.
Old May 31, 2010 | 02:31 PM
SVT_BRYAN's Avatar
I have the low oil pressure light too. I've added oil and checked the dipstick level and it's fine. It's annoying because it's taking up my info cluster and I cant see temp and MPG and stuff.
Anyone else know what to do?
Old May 31, 2010 | 07:13 PM
02A6Beau's Avatar
mine came on shortly after I added the seafoam.
oil change
not had a problem since
Old May 31, 2010 | 10:12 PM
czwalga's Avatar
Member
It may clean out the engine a bit, but I doubt it solves your problem. Change the sensor if it's not that you have a series problem and should park the car haha.
Old Jul 11, 2013 | 10:20 PM
Thomasr17's Avatar
Will sea foam help with my low oil pressure?
Old Jul 11, 2013 | 11:05 PM
Mad Cow's Avatar
It's annoying because it's trying to tell you to stop driving and pay attention to the warning telling you you're destroying the motor. Unless it's the switch or wiring to it, but you should've checked that the second that light came on.
Old Jul 21, 2013 | 09:37 PM
Villani's Avatar
Don't risk the low oil pressure light issue with any temporary fix. De sludge the engine.
Drop the oil pan, clean it up and put on a new pickup tube. Use synthetic and change every 3k mi.
I lost a turbo due to starving because of this problem and a short term fix.
Old Jul 22, 2013 | 10:14 AM
jmarshall098's Avatar
check the oil level and the pump. also check the filter (clogged). this may solve the problem.
Old Jul 22, 2013 | 12:37 PM
Kamil`'s Avatar
I was gonna say, seems like a bad oil pump could also be the culprit.
If your short on cash, go to a junkyard with a couple sockets and wrenches.
radar1
Dec 20, 2014 04:50 PM
Jackmup
Aug 4, 2013 10:41 PM
Dallas09
Aug 30, 2011 05:57 PM
eurostyleb
Sep 22, 2008 09:28 PM
