Secondary air system?
Old Mar 6, 2008 | 01:12 PM
bunceman's Avatar
Default Secondary air system?
Is it posable to remove the system and fool the computer?
Old Mar 6, 2008 | 01:47 PM
cincyTT's Avatar
I'm make believe
Default RE: Secondary air system?
Yes, you need to add in a resistor (available from 20squard) and cnc block off for the combi valve.
Old Mar 6, 2008 | 01:52 PM
Leifer's Avatar
I deleted my secondary air intake (am I talking about the same thing as you?) and got a CEL, but proceeded to clear the codes and it never came back.
Old Mar 6, 2008 | 02:24 PM
cincyTT's Avatar
I'm make believe
The entire system or just a part? If its not a whole (post pump), the code should come back sooner or later.
Old Mar 6, 2008 | 02:29 PM
Leifer's Avatar
It was the entire thing, including the plastic pump that feeds into the stock airbox.
Old Mar 6, 2008 | 02:45 PM
cincyTT's Avatar
I'm make believe
it will come back at some point.
Old Mar 6, 2008 | 03:06 PM
Leifer's Avatar
It's been two weeks. Way to be pessimistic about my car!
Bounceman, relevent to your topic; it's easier to relocate it to the drivers-side, and throw a little filter on it. That way you don't get the CEL. What year is your car?
Old Mar 7, 2008 | 01:01 AM
kraylon's Avatar
what would you gain from doing this other then one less thing under the hood??
Old Mar 7, 2008 | 01:03 AM
chaos92287's Avatar
thats it. its just in the way
Old Mar 7, 2008 | 01:17 AM
kraylon's Avatar
i think ill leave mine alone till it craps out then no more air pump
