service indicator "in 2"
Old Sep 8, 2009 | 12:04 AM
Mr. Phil's Avatar
u can always get stuff online lol... and how do u plan on offering it for "free"
Old Sep 8, 2009 | 12:06 AM
ast03's Avatar
hey andrew can i get that manual?
Old Sep 8, 2009 | 12:13 AM
Jc61990's Avatar
are they showing up where your mileage should be?
if so u can clear them yourself.
Turn off the ignition
Press and hold the button on the left side of the display while turning the ignition on
Service OIL will be displayed
Pull out the button on the right side of the display until the service prompt is cleared
The display should now read ---
If the above procedure does not work, outlined below is an alternative procedure:
With the ignition off, push the right button
Turn the ignition on and then pull the left button
This should clear the warning message --- I have a 2002 A4 Quattro. To reset that Service message, hold down the service button. That's the one with the picture of a wrench on it. While holding it down, turn on the ignition. Let go of the service button and press the "Mode" button just to the right of the service button. It should clear the display.
* This does not work in older models, like an Audi A4 /1.6, 1995. It needs the cable and the program ( e.g. VAG-COM). Even with this, clearing the code (IN1 or IN2) is quite complicated.
Old Sep 8, 2009 | 12:15 AM
Andrew149's Avatar
yeah u can get the manaul asto3 whats ur email
Old Sep 8, 2009 | 12:18 AM
Mr. Phil's Avatar
I DONT WANT TO CLEAR THE CODE!!!! i just want to know if i can find out what service needs to be done
Old Sep 8, 2009 | 12:21 AM
pyropenguin's Avatar
It would help if you would answer my question....
If it is there, it's just a service interval warning. As long as you keep up on your maintenance (timing belt mainly) you can clear it and you'll be fine.
Old Sep 8, 2009 | 12:26 AM
Jc61990's Avatar
the codes are preset to go off every set mileage amount, so its probly nothing, if the previous owner kept up on the maintenance on their own, not by using the service warnings then you should be fine. as long as u know the last time the oil was changed and if the T-Belt was done as said above then u have nothing to worry about
Old Sep 8, 2009 | 12:30 AM
  #18
Andrew149's Avatar
haha ur making phill mad he is lost
Old Sep 8, 2009 | 12:42 AM
  #19
Mr. Phil's Avatar
im trying to do homework and its confusing reading about rebuilding a motor then going to talk about engine fault codes and **** lol
and i have no clue if t belt was replaced ever
Old Sep 8, 2009 | 12:49 AM
  #20
Andrew149's Avatar
well okay fair enough reset the light if it comes back on than you have a promblem ok and than for your t belt to know when to replace it you haft to start the car but someone has to start it for you when you pop the hood listen for any squicking noises if you dont hear it than you bellt is fine
