Shark Fin Antenna
Old Mar 21, 2009 | 12:11 PM
jnunez71's Avatar
Smile Shark Fin Antenna
does any one know if you can put a shark fin antenna on a B5 A4
Old Mar 21, 2009 | 12:32 PM
CCA4's Avatar
My dad always used to say "Given enough time and money, anything is possible."
Yes, you can put a shark fin antenna on a B5, but it would mostly be for looks. The radio antenna is integrated into the rear window glass. If you could find the spot where the antenna lead comes off the window glass to go up to the headunit, then tap into that with the lead from the sharkfin, i suppose it would work? But a better question would be, what could you do with the time and money you'd spend getting a sharkfin antenna to work, that you could have spent on cooler, more useful mods?
Old Mar 21, 2009 | 01:00 PM
kriptonik's Avatar
Most people would use the sharkfin antenna for their GPS signal/antenna.
Old Mar 21, 2009 | 02:21 PM
jnunez71's Avatar
CCA4 you make a good point but my reception sucks that's why i wanted to try the shark fine
Old Mar 21, 2009 | 03:58 PM
CCA4's Avatar
Good point, I have a buddy with an A8 that uses a sharkfin-ish looking antenna for his satellite radio
OP, do you have an aftermarket stereo? My radio reception dropped dramatically after i put in a JVC head unit. I've heard guys talk about in-line FM signal boosters, but I have no personal experience, nor do i know how they work. You might look into something like that?
Old Mar 21, 2009 | 05:33 PM
jnunez71's Avatar
i have a stock one in right but next Sat i'm doing a total re haul on it im putting an alpine radio kicker amp subs and speakers
Old Mar 21, 2009 | 06:35 PM
CCA4's Avatar
hmmm I dunno. I had good reception with the stock unit, but maybe you'll have better luck with an aftermarket HU? Like I said in my first post, its definitely possible. Think you're up to it?
harryd14
B7 Models
Aug 27, 2008 02:32 PM
edwardjkim
Aug 13, 2007 10:22 AM
gabriel84
Oct 16, 2006 04:59 PM
gabriel84
Oct 16, 2006 04:58 PM
gajen0981
Nov 2, 2005 05:02 PM
