short shifter help
Old Jan 17, 2011 | 09:02 PM
euroimport88's Avatar
Default short shifter help
i just got the ebay short shifter wont go in reverse what peace do i have to take a dremal or grind down. can someone send me of pic of it thanks
Old Jan 18, 2011 | 02:09 AM
SAudi's Avatar
ill see if i can get a pic probably tomorrow or wednesday but from what i think is that you still have the push down lock out in. when i did my install i ended up deleteing the push down, so it was just the ball and stick and the associated retaining clips.
Old Jan 18, 2011 | 07:20 AM
CCA4's Avatar
Will it not go into reverse because you can't push the shifter rod down? If thats the case, you need to enlarge and/or grease the slot in the shifter rod. IIRC the slot is on the passenger's side and the lil spring loaded pin needs to slide in that slot freely.
If you CAN push the rod down, but still can't get it into reverse, you need to adjust the connection between the blue adapter that looks like a tuning fork and the actual shift linkage. They're connected with a short allen bolt and the little half-round plate. its a PITA but well worth the hassle once you have smooth shifts.
Old Jan 18, 2011 | 08:02 AM
twinpop171's Avatar
I have the B&M installation instructions in a PDF file if you need them. They definitely helped me out with the ebay SSK install.
Let me know if you need them and I can shoot you an e-mail.
Old Jan 19, 2011 | 01:32 AM
michael12582's Avatar
I bought a ebay SS awhile back and had the same problem. you just have to adjust the shifter right to left. but the ebay SS wont have a push down lock out because of the bottom shift bar isnt bent in an angle like your stock one. the only shifter that i know is good is the jhm shifter. I got it for my car and LOVE IT!!!
Old Jan 19, 2011 | 12:32 PM
kayakman13's Avatar
MY ebay SS has pushdown lockout.
Lately though it has been more difficult to get it into reverse. I somewhat remember it being increasingly difficult before I upgraded shifters though, so I'm not sure if its poor adjustment or something else.
Old Jan 19, 2011 | 12:36 PM
kayakman13's Avatar
Old Jan 19, 2011 | 01:02 PM
CCA4's Avatar
Did you use the stock spring or the one that came with the kit? The kit contains a spring thats intentionally stiffer than stock, not really sure why that is though
jibberjive
Feb 24, 2009 12:57 AM
jibberjive
Jan 9, 2009 09:16 AM
macspeed702
Mar 4, 2008 10:31 PM
Flip
Jan 28, 2008 10:55 PM
jrock
Oct 6, 2007 11:47 PM
