Show off your B5+Modlist
Old Jul 1, 2008 | 05:22 PM
  #101
ilovemyaudi's Avatar
Default RE: Show off your B5+Modlist
these are all really nice pics guys... well done!
Old Jul 5, 2008 | 02:39 PM
  #102
widlcats's Avatar
Default RE: Show Me Your B5
engine
unitronic chip
apr diverter valve
k04
samco hoses
body
clear corner headlights
lowerd
smoked taillights
smoked side markers
debadged trunk
tinted
19 inch wheels
still working on it lots
Old Jul 7, 2008 | 11:20 PM
  #103
Mike-2ptzero's Avatar
Ok I guess I will post up my short mod list for my A4.
ENGINE:
ATW block bored to 83.5 mm
ABA 2 liter crank
JE 8.5:1 Pistons
Pauter Rods
Ported AEB head[/align]RaceWare heads
Schrick 252 cams
1mm over intake valves [/align]Stock size exhaust valves[/align]High lift, high rate valve-spring set with Titanium retainers
VR6 throttle body
Custom Intake Manifold[/align]034 Motorsport Wrinkle painted valve cover[/align]DTH Carbon Fiber Coil Cover
034 Motorsport Solid Engine mounts[/align]Stern Snub Mountfrom Pure Motorsport[/align]Custom Catch Can mounted in stock battery location[/align]Odyssey Light Weight Racing Battery relocated to the trunk
Taylor Battery Box[/align]Custom Power Steering Cooler
NewSouth Performance PowerGasket Plus[/align]Aftermarket Electric Fan
TURBO & EXHAUST:
Full-Race.com manifold
GT35R with .82 ar
Tial 38mm waste gate
Wastegate dump tube
3" down pipe
3" test pipe with dump outlet
3" exhaust to Magnaflow muffler
Custom Evolution Racewerks FMIC with Garrett 24x10.5x3.5 core
2.5" IC pipes
Tial 50mm BOV
HKS Filter
FUEL & TUNING:
034 Motorsport IIc stand alone with 4.5 bar map sensor
96 lbs low imp injectors
034 Motorsport fuel rail
SX adjustable fpr
-6 AN fuel feed line from tank
Bosch Motorsport 044 fuel pump from 034efi
HKS EVC4 Boost Controler
Tuned at 32psi on 110 octane
TRANSMISSION and DRIVELINE:
1.8 trans[/align]Custom 4800 lbs dual diaphram 6 puck clutch
Spec Billet Steel flywheel
034 Motorsport solid trans mounts[/align]Stern rear diff mount and rear diff bushings from Pure Motorsport
BRAKES:
Pure Motorsport Stage 1 kit(front)
SUSPENSION & WHEELS:
Koni shocks(regrooved fronts)
Intrax S4 Sport springs
OEM non sport front sway bar
OEM sport rear sway bar
OZ SL 17x8 wheels
BFG Drag Radials 225/45/17
Wheel stud conversion kit from Eurocode Tuning
INTERIOR:
Cobra Suzuka kevlar race seat
Sparco Racer Steering Wheel
JH Motorsports Solid Short Shifter kit[/align]JH Motorsports Shift linkage upgrade[/align]JH Motorsports shifter stabilizer bushing upgrade
Stewart Warner Gauges (Boost, Fuel Pressure, Oil Pressure and 3.5" 8K rpm Tach)
Autometer EGT gauge
Innovate Motorsport LM1 Wide Band
EXTERIOR:
Painted Lowers
Modded S4 Front Bumper
Fiber Images Kevlar/CF Vented Hood
Fiber Images Kevlar/CF Fenders[/align]Fiber Images Kevlar/CF Doors
Fiber Images Carbon Fiber Trunk[/align][/align][/align][/align][/align][/align][/align][/align]Old dyno.[/align][/align]
Old Jul 7, 2008 | 11:28 PM
  #104
Audi_Skydiver's Avatar
WOW thats impressive!!!! I think you should paint the doors and fenders blue to match your car though.
josh
P.S. Have you run a 1/4 mile yet?
Old Jul 8, 2008 | 12:15 AM
  #105
ORIGINAL: ThePaintballGuy
josh
Car is used to show case our parts so it wouldn't be smart for me to completely paint the doors/fenders because then people wouldn't be able to see them.
Yes I have, this car has been running the 1/4 mile for 8 years now and at this time is the quickest B5 (including the S4's) in the country with a 10.69 at 135+ mph with 2 runs of 10.8's to back them up on the same day. Those runs were done with stock fenders/doors. I plan on removing more weight soon before having a full NHRA spec cage installed and plan on upgrading to a larger turbo to aim for 700whp and 9's.
Time slip
Vids of the 3 runs from last year.
Just took the car to Fontana and ran 11.04 at 133.6 mph in 100 deg temps, adjusted altitude of 4000 ft and a bogged 1.799 60 ft.
Old Jul 8, 2008 | 12:22 AM
  #106
Wow thats impressive. You want to build my car up to show off your parts? I won't paint anything.
I would also put any stickers you want on there. Let me know!
I wish....
Josh
Old Jul 8, 2008 | 12:39 AM
  #107
I actually get people that are willing to pay me to do that.
I do offer nice discounts on parts though.
Old Jul 8, 2008 | 12:52 AM
  #108
How nice? PM Me.
Josh
Old Jul 8, 2008 | 12:56 AM
  #109
hiwords's Avatar
you can use my 2.8 to test for performance parts all you want hehe. i got a question though. for your doors, are they just basically shaved and that's all you did to look like the '96 body?
Old Jul 8, 2008 | 01:53 AM
  #110
ORIGINAL: hiwords
Fiber Images took my doors off my 2000 and shaved the bottom before making the molds. The middle molds on the 99.5+ B5's are different then the 96-99. The doors on my car are CF skin with a Fiber glass frame.
