So now im really baffled..
Old Dec 8, 2011 | 12:57 PM
JAW's Avatar
JAW
Question So now im really baffled..
So my 2001 2.8Q has the sport suspension. I measured the front sway bar and its 25mm, and the rear sway bar is 10mm? please see pic attached.
- I thought the rears were at-least 12.5mm?
Old Dec 9, 2011 | 08:27 AM
JAW's Avatar
JAW
no one else with sport and 10mm rear sway?
Old Dec 9, 2011 | 09:00 AM
CCA4's Avatar
I have the sport suspension but no calipers to measure with. I'll go out with an open-end wrench after work today and see if i can get an estimate of how big it is.
Old Dec 9, 2011 | 10:07 AM
jonbonesjones's Avatar
Moderator
i thought sport was 12-13. whatever it is its too small buy a neuspeed 25mm early christmas
Old Dec 9, 2011 | 11:03 AM
JAW's Avatar
JAW
Well, i just got off the phone with Audi and the looked up my VIN and confirmed that i should have a 29mm front, and a 15mm rear.
So bring on the dealer pissing match, they trying to say I changed it, even though they are Audi stamped/have the confirmed bar codes that match my car,
*Dealers now dumping me on Audi USA, said its not there problem .
Old Dec 9, 2011 | 12:16 PM
cincyTT's Avatar
I'm make believe
You are going to want something larger anyways, so it shouldn't matter.
Old Dec 9, 2011 | 01:20 PM
CCA4's Avatar
^Man's got a point. When you do eventually upgrade, make sure you get a rear bar that comes with sub frame brackets. If you use a larger sway bar with no sub frame brackets, you'll crack your sub frame in no time and then you'll wish you never upgraded in the first place
Old Dec 9, 2011 | 01:41 PM
chocalotstarfish's Avatar
Super Moderator
Audi USA usually has much better customer service than the dealers
Old Dec 9, 2011 | 06:02 PM
JAW's Avatar
JAW
True. I was thinking of just doing the rear anyway. Would poly bushings be to much, or just stick with rubber?
Any1 recommend a good rear kit no bigger then 22mm with a sub frame brace, maybe around $200us ?
steve48
Jan 13, 2015 03:55 PM
Lizardwizard
Jul 5, 2013 01:13 PM
FASTER
Oct 10, 2010 10:08 PM
scotts custom
Jul 22, 2007 08:11 PM
antigenus
Apr 5, 2007 05:18 PM
