Speakers/ Head unit
Old May 13, 2012 | 07:03 PM
vgo's Avatar
vgo
Bose or nonBose, there's a built-in amp in the left rear deck speaker for the rear speakers. The front gets powered by the HU.
Old May 13, 2012 | 08:23 PM
Sheasta's Avatar
I see. Ok There are no bose logos on the speaker grills. No bose on the radio when I turn it on. Also its a 1999.5 and doesnt even have a cd player. Only cassete and radio. So Im gonna assume its not bose?
Edit:
I believe the non-bose have 4" in the front. Is there like an adapter so I can put 5 1/4" in the front instead of 4 "? If not can I use these?
http://www.ebay.com/itm/ALPINE-TYPE-...item41657bcade
Is there a problem with switching out components to 2 way like those? I couldnt find any 4 " component only 2 way. If I can use those speakers then do I have to disconnect the tweeters or can I keep the tweeters and also run those 4" 2 way?
Old May 14, 2012 | 12:22 PM
Sheasta's Avatar
Bump. Im trying to buy this asap cant stand the blown speakers. Need to get this all straightened out.
Old May 14, 2012 | 02:23 PM
jonbonesjones's Avatar
Moderator
i used 5.25 and they fit but i would rather have 4 they would fit in the oem ring and mount a lot nicer.
Old May 14, 2012 | 03:06 PM
Sheasta's Avatar
How did you mount the 5.25 then? Is it component or coaxial? Cuz if i get coaxial 4 inch can i still have the stock tweeter hooked up along with the 4 inches built in tweeter?
Old May 14, 2012 | 03:29 PM
vgo's Avatar
vgo
There's 2 wires(a negative and positive) in each speaker. You can leave the tweeters the way they are and should still work.
I'm sure you'd come up with something to mount the speakers. I had no plan prior to buying the replacement speakers. I took it off then just came up with the idea on the spot. Dont forget to consider the depth of the speakers....
Old May 14, 2012 | 06:51 PM
Moderator
you want a component system or just a 4inch mid since you already have a tweeter the only thing the component will do is separate frequencies for you.
Old May 15, 2012 | 01:25 AM
  #18
Sheasta's Avatar
I coukdnt find any seperate 4 inch mids or components. Only coaxial. But i can get 5.25 components but dont wanna ghetto tig install them. I want it yo be quick and painless.
Old May 15, 2012 | 07:15 AM
  #19
Moderator
it took me 5 minutes. i built a wood ring
and look harder next time
http://www.google.com/search?client=...w=1440&bih=678
Old May 15, 2012 | 12:56 PM
  #20
Sheasta's Avatar
I see that but none of those are brands i know. I want like an alpine or jl speaker. But they only make 2 way coaxial they dont have just a seperate mudrange speaker. But maybe ill grab those power acoustics cuz theyre so cheap.
