speed increase
Old Feb 28, 2008 | 10:15 PM
rlubbers's Avatar
Default speed increase
im looking at a 1997 audi a4 quattro 1.8t. It has borla exhaust, hugo ignition module, turbo blow off valve, and a cold air intake. It also has sport suspension springs. Will this increase the speed of the car any? Or does it just make it run better?
Old Feb 28, 2008 | 10:21 PM
mr.cAp's Avatar
Default RE: speed increase
thease things will increase horsepower, but as far as top end speed, unless you have a chip that removes the govner you will be limited,
think of you engine as a giant air pump the quicker you get the air in and out the better it will run
Old Feb 28, 2008 | 10:33 PM
qUaTtRoA4's Avatar
you need to search!!!
fu<k BOV....DV ftmfw!
ummm...you need to get a chip and a DV if you want your car to go any faster
gl!
Old Feb 29, 2008 | 12:41 AM
turbo kraut's Avatar
Tech Guru
ORIGINAL: rlubbers
im looking at a 1997 audi a4 quattro 1.8t. It has borla exhaust(helps some... not a ton), hugo ignition module(wtf is this?), turbo blow off valve(sounds like a cheap ebay bov, get a forge 006/7 or forge 004), and a cold air intake(won't help any really other than make the bov louder). It also has sport suspension springs(maybe better handeling, which will make you faster in the turns). Will this increase the speed of the car any? Or does it just make it run better?
not really and what you got deffinatly not
Old Feb 29, 2008 | 01:06 AM
chaos92287's Avatar
ORIGINAL: qUaTtRoA4
gl!
hater
Old Feb 29, 2008 | 01:11 AM
qUaTtRoA4's Avatar
takes one to know one...lol
rlubbers....the newbie guide is in Chaos's sig above....
^that's some pretty helpful stuff!
Symko
Audi Q7
May 10, 2011 12:54 PM
JaMeS_AudiA4
Jun 30, 2008 01:25 PM
LLOYDskeez
May 21, 2008 07:07 PM
audir8
Mar 27, 2007 09:32 PM
syndrome69
Aug 6, 2006 05:13 PM
