Speedo won't work + CEL
Old Jul 27, 2010 | 04:27 PM
SPhilli911's Avatar
Default Speedo won't work + CEL
I searched and couldn't find anything about this.
Car is a 2000 A4 1.8T Quattro.
I was driving around in my car when I noticed that as I hit the gas, the speedo needle would jump all over the place and sometimes not work at all. About 10 minutes into the drive my check engine light came on. The car still drove fine, though.
I assume the problems are related. Any info would be greatly appreciated. Thanks in advance.
Old Jul 27, 2010 | 05:09 PM
audi guru's Avatar
The first thing to do iS get the code read. Also you could try taking the speedo off and seeing if it's a loose connection but I highly doubt that... But if it is then that's an easy fix. Just take the plastic piece above the steering wheel off and unscrew the 2 screws and wiggle it out from the bottom first. Also just look at it cuz it could be obvious what it is.
Old Jul 27, 2010 | 06:57 PM
SPhilli911's Avatar
Okay thanks I'll take a look at that. Would that cause the CEL to come on?
Old Jul 27, 2010 | 09:50 PM
SPhilli911's Avatar
I checked the connection and it seems to be okay. Any ideas what else it could be?
I really just want to know if it sounds like it could possibly be a serious issue and if I should drive it or not with the check engine light still on. I plan to bring it in to my mechanic asap, but I still need to drive it. :/
Old Jul 28, 2010 | 12:44 AM
Dallas09's Avatar
If the only problem you are experiencing is the needle and CEL, it should be fine to drive. The next step is to drive it to a mechanic or scan for codes.
Old Jul 30, 2010 | 02:06 PM
SPhilli911's Avatar
Just an update for anyone who may come across this thread in a search.
So the car did have a bad sensor, which is being replaced this week. That's about it.
My mechanic did warn me that is still could possibly just be a bad instrument cluster all together. And those ***** are expensive...
Old Jul 30, 2010 | 09:06 PM
B5 Audi's Avatar
I was driving home today pouring rain out side hit the gas to pass a car then needle just dropped the same thing as you car runes fine and every thing just the speedo is down i guess ill have to see taht sensor do you know which one it was that way i can get one ordered
Old Jul 30, 2010 | 09:13 PM
jterranova0's Avatar
You should be able to connect to the cluster with VAG COM to check it out. Speed sensor in the rear diff?
shaun_dumigan_66@outlook.com
Jan 27, 2015 10:46 AM
aberfitch82
Nov 21, 2007 10:20 AM
DUBPORT
Aug 2, 2007 03:38 PM
slocumnb
Mar 14, 2006 12:59 PM
