Speedometer
Old Apr 15, 2008 | 10:53 PM
aberfitch82's Avatar
Default Speedometer
Just got another cluster speedo still dont work changed the and sensor i know the 2 wires that run off the sensor to the cluster i was thinkin about runnin thm directly from the sensor to the cluster and bypassing the computer would my speedometer get a reading that way?
Old Apr 16, 2008 | 01:06 AM
SAudi's Avatar
Default RE: Speedometer
no because the then the computer wont decode the sensor and send a signal to the cluster. also do you have any stored codes that reveal if a speed sensor is out or did you jst replace them all.
Old Apr 16, 2008 | 09:37 AM
the speed sensor code is on now because its not working. We replaced the sensor worked for a while then stopped working. Now I just got a new cluster thinkin maybe it was that still dont work. So I might try and put in a new sensor again and hope that the old cluster was shorting the sensor out. I traced the wires from the sensor to the back of the cluster I have a good connection all the way through.
aberfitch82
Feb 20, 2008 05:30 PM
dombombBMX
Dec 1, 2007 11:28 PM
aberfitch82
Nov 29, 2007 10:59 AM
aberfitch82
Oct 25, 2007 01:16 PM
wlgordon332
Jul 1, 2004 04:54 AM
