SpeedTuning ECU, Boost Issue...
yea... ok in my driveway in neutral. its around 18, 19Hg... driving with my foot off the gas is around 20+Hg, can a bad n75 do this?, i bypassed it and hooked the turbo directly to its self. and was boosting 5psi.... so i was like wow ok... put the n75 back and it was back to 13 like before. so i cranked down my splitter and tried again... no difference... also by my intake there is a verry loud tick that would tick faster and faster over time when the engine is running. ill probly have to get under my car tomorrow and see if i got any bad vac lines... anyone got a diagram or a pdf of all vac/boost lines?
The ticking by the airbox is normal. I forget what the valve is called but there is that and also a check valve around that area that might tick. Scan for faults and do a throtle body alignment with vag com. You have that right?
i have the free version how do i do?
I'm still trying to solve my boost issue as well. I spike and hold about 10-11 psi and it's been like this since day one. At idle my vac is at ~20Hg right after start up and goes to ~25Hg after a little warm up. I haven't checked for codes since my vag-com cable has not arrived, but I did replace the hose that goes up away from the dv; it had a few cracks in it on both ends, but apparently that is not where the boost leak is. I also put my stock ecu back in (have an extra) to see if stock boost is lower than it should be, it's like it should be ~6-7psi and vac is ~26-27.
