squeeky suspension??? AND different dash lights
Old May 28, 2009 | 10:32 AM
Nicka430v's Avatar
oh pssshhh i thought it was yours, yeah they are manufacturer specific, the obdII scanner reads something else but gives the right code number all i have to do is take the pcode and look it up in the audi specific codes to get what it really means, i just use the obdII scanner to clear it.
Old May 28, 2009 | 11:09 AM
a2thy's Avatar
Which codes keep coming back? Have you done anything to fix it before using the scanner?
Old May 28, 2009 | 11:37 AM
Nicka430v's Avatar
p1198 and p1199 which in audi means heater cir volts too high/low i havent done anything to it because i dont know exactly whats wrong or how that could make any sence.
Old May 29, 2009 | 10:57 PM
Nicka430v's Avatar
Also i know this is off topic but i dont wanna cluster**** the forums. I have a 98.5(i think) it is a 2.8 but how do i know its a 30v? cuz it could be an early 98, not sure.
Old May 29, 2009 | 11:15 PM
a2thy's Avatar
Do you know when your O2 sensors were last changed? If it's been more than 100,000 miles I can almost guarantee that replacing them will eliminate your codes. Mine threw codes too, which is why I'm replacing them this weekend.
You can find a lot of information about your car (year, engine, factory options, etc) by looking up what the different numbers and letters in your VIN mean. Check to see if the engine code is stamped on the flat surface of the cylinder block, by the right front cylinder bank. Once you have the engine code, Google it to find the specs.
Let me know if all this helps.
Old May 30, 2009 | 11:53 AM
Nicka430v's Avatar
well before i go and buy o2 sensor since your doing yours let me know if it fixes your codes..so you have p1198 and p1199 as well? i'll check out the code thing once i stop being lazy this morning lol.
Old May 31, 2009 | 09:20 AM
a2thy's Avatar
Update on replacing my O2 sensors: The pre-cat one won't get here until the 2nd or 3rd. I hate waiting! That's the last time I ever pay for expedited shipping.
Your codes sound very similar, but not identical, maybe because mine is a 1.8T I don't know. These are the codes I got: P1117, P1115, and P1103. They're all for oxygen sensor heating.
Old May 31, 2009 | 12:37 PM
  #18
Nicka430v's Avatar
hmm mine is strictly for heater cir volts too low and volts too high, how is that possible at the same time?
Old May 31, 2009 | 06:36 PM
  #19
a2thy's Avatar
One of mine says "sensor heating circuit" the other two just say "sensor heating". I'm not much of an electrician, so hopefully someone else will chime in here.
Old May 31, 2009 | 08:37 PM
  #20
Nicka430v's Avatar
yeah other audi people on here are the most useless when it comes to mechanical, deffinetely worst forum ive ever been on for it lol.
