Steering Problem! Help
Old Sep 22, 2009 | 03:50 PM
Audiguy271's Avatar
Default Steering Problem! Help
When im on the interstate (which is where i do most of my driving) my car tends to lean to the right side and feels very uncomfortable, almost like im about to lose control. It usually is only a problem going over 60mph but sometimes if i hit a bumb or take a turn something feels very wrong. Ive had the struts replaced, alignment, new tires, they checked the wheel bearing and said it was fine. Does anyone else have any ideas of what it could be. Im 99% sure its a problem with the passenger side front wheel in one way or another. This really bothers me and while driving on the interstate it feels highly unsafe. Any help or ideas is greatly appreciated. Thanks -Sean
Old Sep 23, 2009 | 03:36 PM
Audiguy271's Avatar
No one has any suggestions? Could it be a bad control arm?
Old Sep 23, 2009 | 04:25 PM
Pjbrof's Avatar
It leans to the right side? Is it pulling I dont understand your description of leaning
Old Sep 23, 2009 | 05:03 PM
ObnoxiousDrunk's Avatar
Tie Rod Ends???
Old Sep 23, 2009 | 07:34 PM
Patty J's Avatar
Member
just replace everything on that side...problem solved : )
but i would think tire rod ends
Old Sep 24, 2009 | 12:35 AM
SAudi's Avatar
i would think either upper control arms or a bad tie rod. also check the aligment specs. most local shops dont want to touch the camber. i had a similar problem a few weeks ago when after replacing my upp CAs the left side was in spec with negative camber the right side had about .02 degrees of postive camber. only fix was to take it to audi and have them shift the engine cradle .03 degrees to give me negative camber after that the cars great again.
Old Sep 26, 2009 | 06:16 PM
Audiguy271's Avatar
Thanks for the ideas. Im gonna replace the CAs and tie rods and ill let yall know if either fixes it.
gold2734
Sep 3, 2009 08:58 PM
Lastb0isct
Feb 17, 2009 03:15 PM
99'A6
Sep 26, 2008 08:35 AM
B5nightrider
Oct 3, 2005 03:34 PM
mitao2000
Feb 8, 2005 02:41 PM
