Stern Snub Mount
So I just did the timing belt and I replaced my mount (which was in great shape), with a Stern. I was hoping I would notice a difference, but I dont at all, shifting is the same, shifter movement on/off throttle is the same... Do I need a new snub surround too or what?
I gave them a once over, the engine doesnt really move too much. Its hard to tell cause they have that rubber cover, should i just get under there and try and lift that rubber cover up. I also heard they will leak if they are bad, dont know if thats true?
Well I thought I did, i read that writeup on audizine and it didnt seem like there was much to it, i just slid it on as far as the old one was and thats about it.. I didnt have a vibration at idle so i didnt adjust the bracket.
Not going to notice a big difference if your stock one was good.
Upgrading the engine/transmission mounts will really tighten up the driveline. If you dont want too much vibration its best to upgrade the engine mounts, passenger side transmission mount and leave your driver side transmission mount OEM. Since you have the Stern snub, you can go Stern Motor mount (soft) and Stern Passenger side transmission mount.
zipnsplat
Jul 12, 2009 11:22 PM
