Sticky Buttons
Old 02-22-2011, 03:11 PM
BThomas220@Gmail.com's Avatar
Default Sticky Buttons
Alright, so I just got my first Audi.
The climate control buttons are very sticky. The previous owner was a smoker and I think the tar got into them. They are very hard to press the buttons in if it is not warm in the car.
If anyone has any suggestions on how to take care of this, please post.
Thanks
-Ben
Old 02-22-2011, 03:19 PM
MiamiA4guy's Avatar
Mine's are the same way
Old 02-22-2011, 04:12 PM
Yeah it makes using the defroster a challenge.
Do you think spraying some soapy water on it could help?
Old 02-22-2011, 04:32 PM
JoBuNY's Avatar
What about using like goo gone? wipe it around everything and keep pushing the buttons in so the goo gone gets down the sides of the buttons?
Old 02-22-2011, 08:21 PM
Aud1A4's Avatar
Why did you buy a dirty Audi. The previous owner probably treated it like ****. How much did you get it for?
Old 02-22-2011, 08:28 PM
NHolzschuh's Avatar
or, they used the cup holder above the radio(like a moron) with an open drink and it splashed everywhere when drivign over a pot hole...
i found cappuccino remnants on my radio, shift boot and headliner
Old 02-22-2011, 08:34 PM
chickeneater's Avatar
I used isopropyl alcohol and cotton swabs on my buttons. It took a few passes to make a difference, but now my buttons work great.
Old 02-22-2011, 09:49 PM
chocalotstarfish's Avatar
Super Moderator
It's likely from soda being used in the top cup holder. To clean remove it and cafefully you can remove the buttons and use alcohol to clean it.
Old 02-22-2011, 10:22 PM
joshtaz's Avatar
I had this same problem when I first bought my A4. What i did was take out the radio to get at the HVAC, then take that out, disconnect the front part (where the buttons are) and run it under hot water for about 2 minutes. Finally you just leave it to dry over night and it will be good to go.It's a lot easier than you'd think, I think there's a tutorial somewhere around here.
Old 02-22-2011, 10:26 PM
joshtaz's Avatar
Here's a tutorial I just found, It's not exactly the same (for me at least) cause i have a 2001 but its basically the same
http://www.audiforum.ca/a4-b5-b6-b7-...4-climate.html
or here
http://www.zener.com/audi/HVAC_cleaning/
Quick Reply: Sticky Buttons
