Stranded at the grocery store.
Old Jul 10, 2009 | 10:59 AM
damoa4audi's Avatar
Default Stranded at the grocery store.
I put a new battery in 3 months ago and shortly after my car would just barely turn over and start, but it would always start. then yesterday it barely turned over and started, I drove two minutes and turned off car, and then got back in and nothing, no click no noise. All the power was on in the car though. So I went and bought a new battery, and still nothing, no noise, no start. Does this sound like an alternator issue or starter? Thanks
1997 A4 Quattro 2.8l Auto.
Old Jul 10, 2009 | 11:10 AM
jjcrt2's Avatar
check the starter or the solonoid... plus the cables going to the starter solonoid make sure theres good continuity
Old Jul 10, 2009 | 11:11 AM
2fast4u66's Avatar
Alternator has nothing to do with this. It only charges the battery when it is running. The new battery should have a good enough charge to start.
I would check all the cables going to the starter. Sometimes they can get corroded and won't allow a large amount of amps to be drawn. But sounds like a starter is going out and is out now.
Also, hit the thing starter with a piece of wood or something. More times than not, if the starter is on its last leg this is a small trick to get one more start with it.
Old Jul 10, 2009 | 11:55 AM
damoa4audi's Avatar
Default starter
Thanks for the input. I'm going to grab a small hammer and see If I can get it started. Then go get it rebuilt and put it in. Is that very tough to refit?
Old Jul 10, 2009 | 12:03 PM
hiwords's Avatar
if you have power then you're alternator and battery is good. it's probably the starter solenoid but you should just buy a whole starter with a new solenoid on it so you don't have to worry about anything in the future.
jkr66stang
B8 Models
Jan 15, 2009 12:48 PM
bikebarn5
B7 Models
Feb 12, 2008 06:05 PM
PJTocci
Aug 21, 2006 11:28 AM
