Swap an S4 transmission
Old Jan 19, 2010 | 03:23 AM
Mouse4's Avatar
Default Swap an S4 transmission
My tranny is making a winding noise in 1st and I've read of others who have the same issue. Appears to be a known problem with 2001 B5's.
Is it possible to slap an S4 tranny in without any mods? It would be cool to have a 6th gear
Old Jan 19, 2010 | 04:29 AM
Andrew149's Avatar
yeah i wouldnt do just cause the finial drive is the same as the 5 speed and your shift more and you have more weight now a 2.8 manual is a good trany for the 1.8t
Old Jan 19, 2010 | 01:33 PM
Mouse4's Avatar
I should have mentioned I have a 2001 2.8 manual. I wanted to know if I could drop in an S4 6spd manual? Would it just bolt in or does it require mods?
Old Jan 19, 2010 | 02:22 PM
Andrew149's Avatar
it will bolt on and its pointless
Old Jan 20, 2010 | 12:50 AM
Mouse4's Avatar
Why do you think it's pointless?
The 2.8 manual tranny has a known issue with the 1st gear busting teeth off and making obnoxious noise when in gear. I have this issue.
I'm not aware of the S4 tranny having the same issue. I may be wrong?
If it doesn't have the issue, I would rather replace mine with one that will never have this issue again.
Not to mention, I would love to get a 6th gear, right?
Thoughts...
Old Jan 20, 2010 | 03:20 AM
Andrew149's Avatar
didnt i say already whats wrong with the s4 tranny its pointless to have.
Old Jan 20, 2010 | 10:25 AM
Mike-2ptzero's Avatar
No it is not just a bolt in mod. You will need just about all of the S4 drivetrain including the rear diff since it has a 4.11 vs the 3.89 in the A4 1.8t/2.8 01A transmission.
Old Jan 20, 2010 | 11:46 AM
hiwords's Avatar
exactly as mike says. it not a direct bolt on. 6th gear wouldn't be so fun on the highway i don't think. nor would it be fun doing 30mph in 6th. it is cool to have but you won't use it often i don't think
Old Jan 20, 2010 | 03:38 PM
That transmission is really best on the car it came with which has plenty of tq down low. The problem is the 01E 6 speed has a very tall 2nd gear which means you end up really low in the rpms coming out of 1st.
Old Jan 21, 2010 | 06:35 PM
Mouse4's Avatar
It looks like my best best (to resolve the tranny issues I have), is to get a rebuild. I've searched high and low for rebuilds but only come up with dealership remanufactured for $4500 bucks. Not going there.
Is anyone aware of other options? Other than just purchasing a "low miles" used tranny in.
