T04E on a4
Old Aug 16, 2013 | 01:22 AM
ThatRetardedKid's Avatar
Default T04E on a4
I have a .50 inlet .63 exhaust t3 t04e I wanted to know what else is needed to complete this setup. what best injectors to run and mass air flow sensor what RPM's will I be spooling at and how much estimated power will make? I have a turbonetics 38mm wastegate and a stage 3 six puck clutch.
Old Aug 16, 2013 | 12:19 PM
Mike-2ptzero's Avatar
Well first off you will need to upgrade the rods in your motor. You will need a T3 manifold that uses a 38mm WG and get a down pipe or make one to fit the housing on your turbo.
Injectors will depend on the tuner and same goes with the flow sensor. So the first thing you want to do is talk to the tuners to find out what works best for that turbo.
Is it a 50 trim you have?
Old Aug 16, 2013 | 01:28 PM
yes sir and all I'm trying to do is break 300 horsepower. what really I have to upgrade rods I thought it was good to 400hp
Old Aug 16, 2013 | 02:05 PM
300chp or 300whp? The stock rods are good for 400chp if the timing is soft, if the timing is too aggressive it can bend the stock rods making less then that.
Old Aug 16, 2013 | 02:11 PM
300whp
Old Aug 19, 2013 | 01:32 AM
You should be fine as long as you aren't being aggressive with the adv timing. But are you really going to be satisfied with just 300whp with a turbo that can make more then that? If not then you might want to look at dropping in a set of aftermarket rods to be on the safe side.
mrb5_supra_wrx
Jun 26, 2013 12:20 PM
getboosted84
Jun 4, 2007 08:05 AM
