Is there an ATF dipstick for 2000 B5?
Old Sep 23, 2012 | 03:47 PM
kxmills's Avatar
Default Is there an ATF dipstick for 2000 B5?
Is there an ATF dipstick for 2000 B5? If so where? If not how do I check It?
Old Sep 23, 2012 | 03:56 PM
02A6Beau's Avatar
no
audi transmissions are sealed. they are supposed to be "lifetime" fluid. you will need a vag-com and a way to get under the car while it is perfectly level. you need to get the transmission up to temperature (hence the vag-com which will allow you to see the trans temp in real time), then you can check the fluid level at the fill plug.
Old Sep 23, 2012 | 03:57 PM
Nemick's Avatar
I don't think there is. If it's the same as the 2001, the only way to check it is to bring the trans temperature up to a specified number and then fill through the trans sump pan until it starts to dribble out. If you don't have a vag-com, you might be better off having a stealership check it for you.
The above poster neat me to essentially the same comment.
Old Sep 23, 2012 | 11:08 PM
kxmills's Avatar
Oh the mythical 'lifetime' fluid. I have 133k on mine I want to change it. What type of fluid is it? How many quarts?
Old Sep 24, 2012 | 01:47 PM
Nemick's Avatar
Start here Audi Automatic Transmission Filter Kit - Vw Automatic Transmission Filter Kit Order a couple of extra quarts too.
Will_02_A4
Nov 5, 2017 02:05 AM
bildo
Feb 8, 2012 02:11 PM
Don_Korcari
May 14, 2010 12:52 PM
SouthernAudi
Oct 11, 2007 07:13 AM
Boober
Dec 20, 2006 10:46 PM
