Thermostat going out?
Old 02-18-2010, 12:39 AM
rplets15's Avatar
Default Thermostat going out?
Hey guys, so my car never warms up to past the first line and its the same deal with my oil temperature. I was thinking this is due to my thermostat being stuck open or just completely gone out. Is that right or no?
Old 02-18-2010, 12:57 AM
evan671's Avatar
Member
I have the same problem, change out your thermostat. Im doing mine next weekend.
Old 02-18-2010, 01:39 AM
2fast4u66's Avatar
Same deal here, lol. I got one on order
Old 02-18-2010, 11:54 PM
rplets15's Avatar
OK sweet I think Ill order one now, btw how much coolant do you think I should get?
Old 02-19-2010, 12:18 AM
auditech79's Avatar
Should only need half a gallon of G12 mixed with half a gallon of water.
Old 02-19-2010, 06:12 AM
fromzerophreak's Avatar
I just got my thermostat changed yesterday and mine was doing the same thing except it wouldn't warm up at all if I drove it. It warmed up one notch away from center when sitting still. All good now tho, I put a piece of card board in the slot by my radiator and that helped warm it a little bit
Old 02-19-2010, 12:42 PM
leighsean's Avatar
mines doing the same thing..you guys post back here if it solves your problem, hopefully this will fix mine too.
Old 02-24-2010, 06:37 PM
evan671's Avatar
Member
I just changed mine today, took about an hour. Here is a pic of after I installed it. Before the temperature needle would never get past the first line now it stays at the middle. Also, the oil temperature gauge is functioning now.
Old 02-25-2010, 11:02 AM
exequiel3k's Avatar
Did you do it yourself?
I read some DIY's on thermostat but they all seem to refer to a TB change..
Is there a way to just change the thermostat without having to go through all the mess of partially taking the front off.. OR, sorry for my ignorance..
Old 02-25-2010, 02:00 PM
evan671's Avatar
Member
I did do it myself. It took about an hour to do. I didn't come anywhere close to messing with the timing belt. First I removed the throttle body, next I removed the intake manifold brace, and unbolt the thermostat housing. Its really easy.
Quick Reply: Thermostat going out?
