thermostat replacement issues (leaking housing)
Car: 1.8T '98
So I'm replacing the thermostat. I purchased the thermostat and the gasket and went to town. Afterwards I put in a bit of water to look for leakage (there was non prior) and like clock work it began to leak. I thought it was the bolt on the right because that one was hard to reach. After a few tries I just moved that bracket out of the way and was able to tighten both fine. Still I saw leakage. I thought it was the hose clamp, I got a new one. Still leaking. By this point I noticed the screws were actually dry so I assume it's leaking from one of the sides of the thermostat housing.
What should have taken an hour I will have to finish tomorrow, but does anyone have any background on this? I had to go from home back to the store constantly to get another object I thought was causing the leak replaced (hose, gasket, clamp).
I'm going to look for a new housing tomorrow. It looks fine to me, but I don't know if that's part of the usual ordeal. Any advice I would appreciate.
Thanks guys.
Thanks guys.
If you check out ECS Tuning's website:
OEM / Performance Parts for Audi, BMW, Mercedes Benz, Mini, Porsche & Volkswagen - ECS Tuning
You'll see it's just the thermostat o-ring. Make sure you have it installed properly; I know from experience that installing the o-ring/housing in the wrong order IS possible and WILL cause coolant to leak. If this isn't your issue, make sure the o-ring is seated properly as it can be a pain to get right.
