These darn brakes
Old Feb 11, 2010 | 03:12 PM
TommyGunns's Avatar
Default These darn brakes
So I'm guessin that I need to replace a caliper. While driving, the car pulls hard to the passenger side. I had an alignment done, that did nothing. I just tried re-greasing the caliper sliders, and its still there. The pads are in good shape, and the rotors are only about a year old. Does this sound like the obvious solution?
Old Feb 11, 2010 | 03:16 PM
Andrew149's Avatar
how hard like bady?
Old Feb 11, 2010 | 03:20 PM
TommyGunns's Avatar
When I let go of the wheel, it jerks to the right.
Old Feb 11, 2010 | 03:29 PM
Andrew149's Avatar
damn that is bad, push both the calipers in and see if one isnt as smooth as the other
Old Feb 11, 2010 | 03:39 PM
TommyGunns's Avatar
I'm guessin that maybe there is a catch, and its not fully releasing.
Old Feb 11, 2010 | 03:54 PM
Andrew149's Avatar
yep lub it up push it in pull it out and see what you get
Old Feb 11, 2010 | 05:16 PM
TommyGunns's Avatar
Lube up the piston? How would I do that without rebuilding it? What kind of lube?
Old Feb 11, 2010 | 05:27 PM
Andrew149's Avatar
umm i would use white gree just slip the black cover off and lube it up around and than put it back on
Old Feb 11, 2010 | 06:01 PM
TommyGunns's Avatar
You mean the rubber around the piston? Wouldn't that cause it to leak?
Old Feb 11, 2010 | 06:02 PM
Andrew149's Avatar
yep and no its to keep dirt out
