things that go wrong with ALL A4's
I have a 99 with 164K 2.8 V6
Most of the problems the group mentioned earlier I have also seen:
Door trim replaced 90K
Water pump 85K and 130K
Wiper motor and transmission
Blinker relay 2x
Rear wheel bearings
Rear CD disk changer 100K
Coolant sensor 2x 40k and 80k
O2 sensor light on now!
Rear axle seals leaked from 40k
Bad r/h control arm now!
Spider piping bad-actually disintegrated 130k
Leaking valve cover gaskets 2x
Flaky switch on Cruise control
Blinker relay 2x
Rear wheel bearings
Yes. But most Autozones nowadays won't clear codes. You can either buy an OBDII scanner for about fifty bucks or you can buy Ross-Tech's software then head over to eBay and buy an OBDII/USB cable. From there you can clear all your codes and whatnot through your laptop.
I have this same thing happen to mine. whats the best way of getting this fixed?
Real easy... check out ECSTuning for the replacement parts. It will take you 5 min to swap out...
Exactly the same issue mate, makes it bloody awful....
