throttle body?help
ok heres the scoop turn the key to on postion the throttle body is clicking and moving radicaly fule pump relay clicking as welland punp in tank clicks on and off. also when you turn key to on position no comunication with computer but if you actualy get car to start you can retrieve codes except for engine codes.replaced throttle body tryed readaptaion but with the key in on position you cant get comunication with computer??? WTF???? HELP PLEASE
I guess your asking about the throttle adaption? press throttle peddle to the floor then turn the ignition on ( don't crank the engine ) this is to set WOT ( wide open throttle ) the fuel pump should only click/cycle once to pressure the system and if it keeps clicking then you have an air/fuel leak
kraylon
Sep 2, 2009 09:32 PM
brent07
Aug 10, 2005 02:46 AM
