Ticking Noise
Ok so I have a 99 A4 2.8 Manual Quattro.
I recently had the timing belt changed about 2 years ago and around a month ago I started to notice a loud ticking sound. I am unsure where to begin, is it the timing belt? I live on Long Island and I have no idea where to bring it if anyone knows any good shops who work on audis for a good price or any ideas as to what the problem is it would help me out big time. Thanks |
You may be getting low on oil. Our cars "tick" when they need oil.
i checked the oil...the oil level is good...so it cant be that.
If the timing was off would it tick? |
Bring that the timing belt was done two years ago how many miles have you put on since? How often does it tick just on warm up or when it's running at temp? Does the tap match with the rpms or does it fade out after idle?
the ticking gets faster when you accelerate but it is not as loud as when i am in idle...any ideas what i should do?
Have you tried a thicker oil see if it goes away?
ok so i just completed an oil change i put castrol syntec synthetic 10w - 30 oil in and some marvel mystery oil. The ticking is still there...i'm confused. The engine seems likes its purring but I can still hear the ticking. Any ideas?
maybe serpentine belt is going bad?
Can u post a sound clip?
if its at the back of the engine near the top then it probably is your cam tensioner.
pop the hood and take a listen at it. |
