Timing belt ?
Old Apr 14, 2011 | 12:06 PM
wtlee3's Avatar
Default Timing belt ?
1999 Audi A4 Quatro 1.8T
Just recently put a new timing belt & tensioner on my car and have been driving it a while. I had someone hook it up to their computer and they said it was throwing an occasional cam sensor error. A quick check showed the cam was off two teeth. I pulled the front off far enough to get to the top timing belt cover but cannot compress the tensioner.
- Is there a way to compress or remove the tensioner without removing the bottom cover?
- should the crank pulley mark and camshaft mark line up perfectly?
- what size torx bolt is on the crankshaft pulley?
Thanks
Old Apr 14, 2011 | 12:22 PM
DOC_DEPALMA's Avatar
I'm pretty sure the crank-pulley bolt is a 6mm allen but I could be wrong...but I dont think I am
Old Apr 14, 2011 | 12:30 PM
gdog87's Avatar
I read somewhere on here that sometimes the two tdc marks don't line up exactly, and you should check and proof mark it yourself during dismantle.
G
Old Apr 14, 2011 | 07:22 PM
ImTheDevil's Avatar
Agreed with both these guys, and as for compressing the tensioner, you will likely need to dismantle it all. I would anyway - it's easy and lets you see everything much better.
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
TheBat
Jun 20, 2008 01:14 PM
