Timing belt failure likely?
By the way I picked up a Duralast timing belt at Autozone, and after reading some online reviews I'm thinking I may not want to use it after all.
type in "duralast timing belt" in google and read all the people who are questioning using them.
blauparts.com usually has the best prices.
again, if you are opening up the car to do the timing belt, you might as well do the rest while your in there. its up to you though if you want to do it. that stuff may last untill your next t-belt job. or it may not.
I need my car back on the road ASAP so I'll just do the TB and water pump. I will however, change all the components again in about 60,000 miles instead of the typical 80,000. Does the tensioner usually gradually loosen over time? or does it just give out all at once? I check the tension and condition of the TB every time I move the core support, so if I notice any problems I'll replace it.
Ok, I have the TB off and the water pump replaced. I made my alignment marks, but when I released the tensioner both the cam sprocket and crank sprocket rotated slightly. There won't be a problem if I just rotate them back to their original positions before installing the TB, right?
you can rotate them as much as you want, as long as they line up with the timing marks you should be good. when you put the new belt on it may look like the belt is half a tooth off in one direction. when the tensioner puts pressure on it they should line up then. just push on the belt where the tensioner would to check if its off the wrong way.
