Timing Belt, I'm fucked.
Old May 3, 2010 | 10:29 PM
  #21
NickBroderick's Avatar
There is a car somewhere here that has like 130k on org. but why risk it?! I mean seriously?!
There's a car on here that has 170k on the clock with the original timing belt. How do I know this you ask? Because that car is mine.
This thread makes me want to replace mine. Now.
Old May 3, 2010 | 11:28 PM
  #22
Dallas09's Avatar
haha you should leave it, in the interest of the forums, just so we can see how long it can go.
Old May 4, 2010 | 12:04 AM
  #23
Andrew149's Avatar
well nick you can tell when a timing belt is gone by a service tag maby go to the dealer and have them look it up other signs loud noises sounding like a bearing whem you rev your car up other example my car sounds like a train when i floor it you can heat it for 2 miles i will have a video for everyone
Old May 6, 2010 | 07:02 PM
  #24
DOC_DEPALMA's Avatar
Default i see
Originally Posted by Andrew149
he honestly do a engine swap its most likly to be cheaper call shokan.com they will have your car up and running they have every part no matter what
i see your car at the crabtree mall in that pic, do you live in the raleigh area? jw I live in fayetteville
Old May 8, 2010 | 09:31 PM
  #25
turtleboy's Avatar
When in doubt, change the timing belt. If you don't know when it was last changed, CHANGE IT.
Old May 8, 2010 | 10:11 PM
  #26
jmgrande's Avatar
100% right answer.
Old May 8, 2010 | 11:19 PM
  #27
Midniteoyl's Avatar
Just because the car wont start doesnt me the valves are bent... most likely the timing is off or you forgot something.
Now, that does NOT mean they ARE ok... obviously.
Old May 22, 2010 | 12:14 AM
  #28
Default Pretty sure
Im pretty sure I had it timed right, and everything else is put back together, I went over it several times.. idk I priced two heads off Shokan.com and they want about 450 for them... gotta get the paper together first... so once again im without a ride.
Old May 22, 2010 | 12:23 AM
  #29
rawdney88's Avatar
Originally Posted by jmgrande
Do your water pump and timing belt by 80k miles as per the 80k miles service and you'll have nothing to worry about.
actually i did mine 2 weeks ago at 60k miles. needed to fix oil leaks on the valve cover and cam seals connected to the belt itself. killing two birds with one stone. i want lowers and rims now...
Old May 22, 2010 | 01:10 AM
  #30
10kRedline's Avatar
Man, thank god my belt snapped when I started my car in the morning....
