Which timing belt kit???
Old Dec 18, 2010 | 08:52 PM
yellow_submarine's Avatar
Default Which timing belt kit???
Hi everyone! I just got my 2001 audi a4 1.8t quattro last week. Now im currently looking into buying a timing belt kit at ecs. Only question i have is which kit should i buy and what does the awm or aeb-atw mean? how do i find out which one is mine? thanks!
Old Dec 18, 2010 | 09:43 PM
Aud1A4's Avatar
it an engine code....check out your to see what to buy
Old Dec 19, 2010 | 06:50 AM
is this by vin number? or is there a place where can see it?
Old Dec 19, 2010 | 08:06 AM
chocalotstarfish's Avatar
Super Moderator
If you have an 01 1.8t your engine code is AWM
Old Dec 19, 2010 | 09:34 AM
CCA4's Avatar
Engine codes are available in the FAQ sticky
As far as timing belt kits, I think you should go with the kit from Blauparts. It's cheaper and comes with more stuff. You are gonna need your VIN though, as 2001 was a half model year.
http://www.blauparts.com/products.asp?cat=2322
Old Dec 19, 2010 | 01:15 PM
Andrew149's Avatar
get the all in one kit usualy the most expensive so you will have everything there and you wont need to run to the store
Old Dec 19, 2010 | 05:58 PM
Thanks guys really appreciate it. i'll go buy the kit asap.
Old Dec 19, 2010 | 06:05 PM
is it worth it to get the timing belt tool kit also? or can i do without?
Old Dec 19, 2010 | 06:33 PM
Andrew149's Avatar
most people say it is but other say its not if this is your first time doing a timing belt than i say do it but if you know what your doing you dont need it
Old Dec 19, 2010 | 08:40 PM
bradtyler02's Avatar
I did mine a couple months ago with the full kit from blauparts (just under $300 bucks, and I highly recommend it). Also, I rented the tool kit with no issue with the return or anything, and my deposit was returned to by CC promptly. I only used a couple tools out of the tool kit, but I would have had a really hard time trying to manage without it. IMHO, it was worth the couple of bucks to rent it...
