timing belt question
Old Jun 29, 2011 | 11:47 AM
18psi's Avatar
Default timing belt question
iam working on a 99 6cyl a4. iam changing the timing belt. i have the tool that goes between the cam sprockets and i have the timing marks on the crank pulley and the cover plate lined up, the two questions i have are.
1) why isnt my number one piston at top dead center when all my marks are lined up?
2) does anyone count the teeth between the marks on cams or between cam and crank
thankyou in advance
Old Jun 29, 2011 | 03:22 PM
Audisaurus's Avatar
i think 16 teeth? don't quote me
and cylinder 3 is the index not 1
Old Jun 29, 2011 | 03:41 PM
DOC_DEPALMA's Avatar
He's right it is the number three, back left if you're looking at the engine.
Old Jun 30, 2011 | 10:20 AM
18psi's Avatar
okay, so if i have my special bar on both the cam sprockets and i have the crank pulley marks lined up so number three is at top dead center, then iam good to go and can put on the new belt?
i guess iam asking because iam use to having the crank sprocket marked as well as the cam sprockets and then counting the teeth between the marks.
Old Jun 30, 2011 | 01:05 PM
Audisaurus's Avatar
There is a mark on the crank sproket but yes you sound good to go
Old Jun 30, 2011 | 01:21 PM
There's also a mark on the timing belt cover behind the crank pulley iirc it's around '2 o'clock
Yagimax
Sep 26, 2012 05:29 PM
sollyd25
Jan 11, 2011 01:01 AM
Jessie2k
Aug 5, 2008 01:39 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
cdf619
Oct 25, 2005 05:56 AM
