Transmission Fluid - Sandman's DIY
I have been planning on replacing transmission gear lubricant on my 97 1.8TQM and got the little tool and picked up 3 qts of Mobil 1 75W90 Fully Synthetic Gear Oil. I bought it all at Autozone and didn't know the difference between gl4 and gl5. I was just planning on following Sandman's DIY. I believe the Mobil 1 I got is GL-5. His DIY makes no mention of this number. Should I return the Mobil and order Redline stuff online or is the Mobil gonna be fine? I have searched and haven't been able to find a concise answer.
The only mentions of GL-5 on the back are in two places.
"Outstanding protection of hybrid differentials where API GL-5 quality 75W90 oil is recommended."
and then
"Mobil 1 Synthetic Gear Lubricant 75W90 exceeds the performance requirements of API GL-5."
and then
alot of people are running that you should be fine. i on the other hand went to audi and bought 100.00 worth of stuff for the trans and rear diff. after the fluid change, my transmission is 100% smoother, but still a bit stiff in 2nd gear when cold, which seems to be a common problem
ORIGINAL: duburban
100% smoother? wow. that good huh? i've always wanted to do this.
whats the process for doing the rear differential? im sure there is a write up somewhere... someone wanna throw a quick link in here. this could be a quick easy thread for search purposes for people.
ORIGINAL: CampbellsChunkySoupr
konabiker47
Jan 20, 2009 09:28 PM
