Transmission question
Old Sep 19, 2009 | 10:53 PM
begeta50's Avatar
Default Transmission question
I have an A4 Avant 2.8L with a DRN transmission code. I did not know that all the transmission were the same, so I replaced with a transmission with FAS code. The transmission work good from first gear up to four then the car goes into limp mode, and will not downshift. The transmission will stay on 4 gear.
Is there a way to fix it or do I need to find a DRN code transmission?
I will appreciate any help.
Old Sep 19, 2009 | 11:27 PM
AUDI MY MIND's Avatar
just a thought but check you shifter-is this a tip tronic?-does your cruise quit working at the same time-does the center display quit workin? PRDN5432-if so there is a small magnet located in the under consolethat tells the computer where the shifter is at-it can work loose or misalign- wiggle the shifter gently-does it then go into gear? if you wiggle it to much does it fault out?-had this problem went to a parts store and used scanner to reset it always started to work problem was under the console-hope this helps
Old Sep 20, 2009 | 08:02 AM
begeta50's Avatar
Yes is tip tronic transmission, and cruise also stop working at the same time.
The code reader says that can not read the input speed sensor.
Old Sep 20, 2009 | 07:53 PM
I would go back to the basics - clean all related connectors use dialectric grease - even clean and grease some of the things you are nearby - dialectric grease prevents corrision and moisture build up - reset with the scanner then see what ya get - cleaning and greassing creates a baseline from wich to work - you get a chance to see the wiring-if you need to clean any connectors use some contact cleaner and a toothbrush not a metal one though am not always sure when voltage is present(key on or Off) - keeps me from fryin stuff lol -frayed cracked whatever or hopefully in good shape - if it still throws the code at least you have a place to start - more accurate readings-hope this helps
Old Sep 21, 2009 | 05:26 PM
begeta50's Avatar
I purchased a new crank sensor, but the results were the same. The car is not able to downshift.
Old Sep 21, 2009 | 08:13 PM
You purchased a crank sensor?-thought you said bad input speed sensor?-checked and clean connectors? other sensors can be related to it and not show up-throttle position sensor?-anything related to the trans downshifting- am not familiar yet with all the in's and out's as this is also new car to me but most information transfers from car one to the next-some just ad more junk to it-I accidentally cleared my codes before i could read them so i don't know what they were-but i do know what they were related to(MY SHIFTER ON THE CONSOLE)did you check the harness?- check it again carefully-if it changes when you wiggle it or codes out likely it is the issue-that shifter goes through alot of use over the years- i did download some schematics but have not had chance to look at them yet-will let you know if i find anything and have a code sheet as well-till then
Old Sep 22, 2009 | 04:58 PM
Default get a multimeter
Ok here goes-your gonna love this, told you about the extra goodies
1check supply voltage of trans cntrl module
2-kickdown switch
3-multifuntion trans switch!!!!!! in the console
4-ground connections
5-voltage supply of trans solenoids-7of them including shift lock solenoid
6-trans vehicle speed sensor
7-trans input sensor
8-trans fluid sensor-reading correct temp?
9-wiring connection to-
throttle valve signal!!
consumption signal-what you are getting mpg-estimated
engine speed signal
engine intervention signal-low oil pressure-coolant-ignition etc. - i believe
up/down shift signal
Like I said get the goodies you get the crap to-our local library has excellent manuals for my A-4 All Data i think-not chiltons or haynes have checked the local parts houses as well, you can buy a 1yr subscription for your particular car, downloadable schematics i do believe. Get a meter and get into it because there is more to it than i have listed here. Try not to throw parts at it,just gets more frustrating I am still using a meter that i bought from Harbor freight for less that 5 - 7bucks and it does everything i need, paid for itself hundreds of times over in the last 4-5 years
Again-clean it-grease it-test it-and everthing related to it-check for good battery voltage as well, weak cells can wreak havoc on these cars and it is sometimes nothing more than a low battery-Hope this helps-ttyl
Old Sep 22, 2009 | 05:01 PM
If I'm talkin out my exhuast pipe someone let me know-any other adivice for this is welcome-Later
Old Sep 22, 2009 | 06:43 PM
begeta50's Avatar
Let me ask you. The transmission codes is important or not. Like I said the transmission that installed now is different from the orinal transmission code?
Old Sep 23, 2009 | 12:07 AM
brrman's Avatar
It is likely important - your transmission computer is likely coded for a specific transmission.
