Trouble with AC system and R-134a coolant
Old Mar 27, 2009 | 06:24 PM
jostojic's Avatar
Default Trouble with AC system and R-134a coolant
I've got a 2000 2.8l 30v A4 that I recently replaced my AC compressor on (or rather my dad did it for me). I'm not getting very cold air coming out. I've put about 3 13oz cans of r-134a. According to the gauge on the can, it's at about 42psi of pressure with the compressor running. It seems to max out there. It didn't seem to change much as I emptied the 3rd can. I don't want to overcharge the system. How much coolant should the system hold? Any ideas on what could be wrong? I checked about a week apart, and the pressure seems to stay constant, so I don't think that there is a leak in the system. Any pointers would be appreciated.
Old Mar 27, 2009 | 09:17 PM
Redrum1's Avatar
You didn't mention if you pulled a vacuum on it to remove all moisture and air in the lines before you added the R-134. Thats the first step you need to do.
Good Luck...
Old Mar 28, 2009 | 04:44 PM
jostojic's Avatar
...I didn't vacuum the system first. Thanks for the tip. Does that mean that I'll lose the r134a I've already put int?
Old Mar 28, 2009 | 07:11 PM
somebody5788's Avatar
Go have a shop do it with the proper equipment. You MUST draw a vacuum and put the proper amount of oil into the system or bye bye compressor #2.
jackson-shawn
Jul 6, 2015 11:46 AM
scanny1
Mar 3, 2012 03:03 PM
Rogue321
Feb 13, 2012 10:55 AM
marty823
Jun 19, 2009 10:51 PM
Kristjansson
Feb 11, 2008 10:54 AM
