trouble with code reader connecting to car
Old Aug 28, 2009 | 12:19 AM
a4nick's Avatar
Default trouble with code reader connecting to car
I bought a 98 Audi about a week ago and I have been trying to get the code pulled but every time I use the code reader it says it is unable to connect and tells me to make sure the cars ignition is on. Any help with this? I have no idea where to even begin with this
Old Aug 28, 2009 | 12:24 AM
Andrew149's Avatar
are u useing the rosstech stuff vagcom is the only way to go i would take back what u have and use vagcom
Old Aug 28, 2009 | 12:27 AM
a4nick's Avatar
no I go to schucks and use whatever they have. It worked on my 96 a4 so idk why it wouldnt work on the 98 a4 i have now
Old Aug 28, 2009 | 01:00 AM
A4 2000's Avatar
I just got a Top Tack OBD II scanner from ebay and it works fine. That's strange why it wouldn't work. Are you sure the pins are in all the way? It can be a pia to line it up right sometimes.
Old Aug 28, 2009 | 07:32 AM
Andrew149's Avatar
dont bother useing anything but vagcom
Old Aug 28, 2009 | 08:13 AM
rcheing's Avatar
a4nick, check your radio and/or cigarette lighter fuses. I think one of those control the OBD2 port. Let us know how it turns out. They are located underneath a door inside next to the steering wheel by the driver's door.
Old Aug 28, 2009 | 09:12 AM
CRAZYHAWK's Avatar
Do you have the origonal head unit (radio)?
Old Aug 28, 2009 | 12:51 PM
a4nick's Avatar
Yah i have the original head unit in there still and ill check my fuses but both my radio and cig. lighter work right now so idk if that will be the problem i plug it in and it feels like it goes in like butter which was wierd to me. my 96 there was a little resistance and it actually felt like a plug on my 98 it feels like nothin really.
Old Aug 31, 2009 | 08:30 PM
a4nick's Avatar
checked the fuses and they were fine.. any other ideas?
Old Aug 31, 2009 | 08:53 PM
Andrew149's Avatar
Check to see if u have any bent pins and if so bend them back and very carefully it happends
