Trouble Codes
Old Aug 28, 2012 | 01:15 PM
ImTheDevil's Avatar
Quick correction - bank 1 is passenger side and bank 2 is driver side.
Old Aug 28, 2012 | 04:53 PM
CCA4's Avatar
I fail x2 lol
Old Sep 17, 2012 | 07:24 AM
CStites's Avatar
Quick follow up... I went to an AutoZone and cleared the codes with a scanner and haven't had the codes pop in over 2 week!
Not sure what was causing the codes, thinking it may have been a heavy load on the car as it was slammed with belongings while I moved across the country.
Old Sep 17, 2012 | 08:23 AM
redline380's Avatar
Legal Moderator
good to hear. update if it comes back
Old Dec 20, 2012 | 12:12 PM
Ben Eshtamoa's Avatar
Default 1.8t similar issue
I don't mean to hijack the thread, but seeing as there are a lot of smart folks on this thread i'll explain my situation with as much info as i can give. 3 codes, Cam Position sensor, Bank 1 Lean, Bank 1 Rich. Lean comes from cam position sensor. Rich i think comes from the ecu adjustment to the lean code? BUT, i did blow the intake pipe off from the cold side turbo outlet about 3 weeks ago. Car is stalling, and i believe it is from the rich mixture. I also have 1lb of boost, where i had about 11 before all this started happening. Is it the pipes, MAF, TB or something along that line, or is it the rich mixture, or something else i didn't think of?! thanks tons, again sorry for hijack!
devlzluv
Aug 1, 2010 02:07 PM
Deekster22
Sep 13, 2009 01:22 PM
2000turbo
Nov 21, 2008 05:25 PM
edrocks3
Nov 1, 2007 03:03 PM
acvega
Mar 10, 2005 10:30 PM
